The ProLite T1732MSC 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The Anti Glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
Touch technology - Capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
IP54
The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
Speakers
This LED monitor is equipped with two high quality stereo speakers.
 - iiyama ProLite T1732MSC-B5AG - LED monitor - 17"
 - LED-backlit LCD monitor - 17" - touchscreen
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/373260
- Energy Class
 - Class E
- Energy Consumption per Year
 - 27 kWh
- Power Consumption (On mode)
 - 11.9 W
 - Touch-screen
- Panel Type
 - TN
- Aspect Ratio
 - 5:4
- Native Resolution
 - 1280 x 1024
- Pixel Pitch
 - 0.264 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1
- Response Time
 - 5 ms
- Colour Support
 - 16.7 million colours
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Tilt
- Screen Coating
 - Anti-glare
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black
- Image Colour Disclaimer
 - The displayed product image may be a different colour
 - 38.7 cm x 20.2 cm x 34.2 cm
 - 5.6 kg
 - Plug and Play, VCCI, DDC-2B, CB, cULus, IP54, TUV Bauart, CU
- Display Type
- Energy Class
 - Class E
 - 27 kWh
- Diagonal Size
 - 17"
- Panel Type
 - TN
- Aspect Ratio
 - 5:4
- Native Resolution
 - 1280 x 1024
- Pixel Pitch
 - 0.264 mm
- Brightness
 - 250 cd/m²
- Brightness w/touchscreen
 - 215 cd/m²
- Contrast Ratio
 - 1000:1
- Colour Support
- Response Time
 - 5 ms
- Vertical Refresh Rate
 - 50 - 75 Hz
- Horizontal Refresh Rate
 - 31 - 80 KHz
- Horizontal Viewing Angle
 - +85 / -85
- Vertical Viewing Angle
 - +80 / -80
- Screen Coating
 - Anti-glare
- Backlight Technology
 - LED backlight
- OSD Languages
 - English, German, French, Italian, Spanish, Japanese, Chinese
 - Cable management cover, HDCP, edge-to-edge glass, OSD lock, scratch-resistant, Advanced Frame Rate Control (AFRC), glove touch mode
 - Black
 - 38.7 cm x 20.2 cm x 34.2 cm - with stand
 - 5.6 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 1 Watt
Input
 - Touch-screen - touchscreen
- Movement Detection Technology
 - Projected capacitive
 - VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
 - Tilt
- Tilt Angle
 - -5/+90
- VESA Mounting Interface
 - 100 x 100 mm
- Included Accessories
 - Cable cover
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 11.9 W
- Power Consumption SDR (On mode)
 - 11.9 kWh/1000h
- Power Consumption (Typical)
 - 20 Watt
- Power Consumption Stand by
 - 2 Watt
- Included Software
 - Drivers & Utilities
