iiyama ProLite T1731SR-W5 17" 1280x1024 5ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ19WS00 Mfr#: T1731SR-W5
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), HDMI, DisplayPort
£252.64 ex VAT
£303.16 inc VAT
ProLite T1731SR-W5 is based on 5 wire resistive touch technology. The price / performance ratio is ideal for the budget conscious user while quality and performance are certainly not compromised. The display inputs include both analogue and digital (VGA, HDMI and DisplayPort) with touchscreen connectivity via USB offering great flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. The ProLite T1731SR-W5 can be used in a variety of environments, especially recommended for shops, restaurants and industrial purposes.
  • Enhanced durability
    Equipped with a scratch-resistant screen and an IP54 rating, this monitor is designed to withstand the rigors of daily use while maintaining its pristine appearance.
  • Versatile connectivity
    Featuring HDMI, VGA, DisplayPort, and USB interfaces, this monitor offers a variety of connectivity options to suit all your needs, ensuring compatibility with a wide range of devices.
  • Optimal viewing experience
    With a 17-inch anti-glare screen, LED backlighting, and 5-point multi-touch capability, this monitor delivers clear, vibrant visuals and interactive touch control for an enhanced user experience.
  • Ergonomic design
    The tilt functionality allows for a comfortable viewing angle, ranging from -5 to +90 degrees, making it easy to find the perfect position for long hours of work or play.
  • Efficient performance
    Class E energy efficiency with a power consumption of only 12.9 W in on mode, this monitor combines performance with energy savings, making it an eco-friendly choice for your workspace.
iiyama ProLite T1731SR-W5 - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Class
Class E
Energy Consumption per Year
20 kWh
Power Consumption (On mode)
12.9 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
38.7 cm x 20.1 cm x 34.2 cm
5.8 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
20 kWh
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, scratch-resistant
White
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 80% light transmittance
USB cable , HDMI cable , Audio cable , DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
12.9 W
12.9 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
Diagonal Size: 17in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: iiyama
