ProLite T1731SR is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linearization.
DVI-I/DVI-D input connector
This device is equipped with one DVI-I or DVI-D input connector. -
VESA mounting
This device can be installed with the use of holders, which comply with the VESA standard. Thanks to this functionality, with the help of proper handles, the device can be mounted on a wall, a ceiling or other surface.
- iiyama ProLite T1731SR-W1 - LCD monitor - 17"
- LCD monitor - 17" - touchscreen
- Touch-screen, stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 900:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 38.7 cm x 34.2 cm x 20.2 cm
- 5.7 kg
- Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 17"
- Built-in Devices
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 900:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- +85 / -80
- Vertical Viewing Angle
- +85 / -80
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- White
- 5.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Resistive
- Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
- Tilt
- Tilt Angle
- 95
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x serial cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by / Sleep
- 2 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Apple MacOS, Microsoft Windows 95/98/ME/2000/XP
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
