iiyama ProLite T1731SAW-B5 17" 1080x1024 5ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ1DWS00 Mfr#: T1731SAW-B5
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£342.89 ex VAT
£411.46 inc VAT
The ProLite T1731SAW-B5 offers superior image clarity and screen durability. The screen can be touched with a soft stylus, finger or gloved hand making it suitable for a number of applications, and the solid but flexible stand ensures resilience in demanding environments. Menu buttons are located on the side of the screen which can be locked to prevent tampering, and include a handy function to deactivate the touchscreen for cleaning.
  • Efficient power usage
    With a power consumption of only 20 W during operation and a mere 3 W on standby, this monitor is designed for energy efficiency, making it an eco-friendly choice for users concerned about their energy footprint.
  • Versatile connectivity
    Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers flexible connectivity options, allowing it to easily integrate into any workspace or home setup.
  • Optimal viewing experience
    Featuring a 17-inch display with a 1280 x 1024 native resolution and WLED backlight technology, this monitor delivers crisp, clear images. The matte screen coating reduces glare, enhancing visibility in various lighting conditions.
  • Responsive touch technology
    The surface acoustic wave touchscreen technology provides a responsive and intuitive interface for users, making it ideal for interactive applications and enhancing productivity.
  • Durable and secure
    Designed with an IP54 rating for dust and water resistance, along with a Kensington security slot for anti-theft protection, this monitor is built to withstand the rigors of daily use while ensuring data security.
iiyama ProLite T1731SAW-B5 - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/374978
Energy Class
Class E
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
12.3 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
Voltage
38.7 cm x 20.1 cm x 34.2 cm
5.8 kg
Plug and Play, VCCI, GOST, DDC-2B, IP54, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
22 kWh
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
230 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+85 / -80
Vertical Viewing Angle
+85 / -80
Screen Coating
Matte
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Surface acoustic wave
HDMI , VGA , DisplayPort , USB
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 92% light transmittance
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Input Voltage
12.3 W
12.3 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
3 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
Diagonal Size: 17in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
