The ProLite T1532MSC 15" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colors.
IP54
The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
- iiyama ProLite T1532MSC-B3X - LED monitor - 15"
- LED-backlit LCD monitor - 15" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 700:1
- Response Time
- 8 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 35.1 cm x 20.2 cm x 30.65 cm
- 4.5 kg
- VCCI, CB, cULus, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 15"
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 350 cd/m²
- Brightness w/touchscreen
- 315 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.4 - 60 kHz
- Horizontal Viewing Angle
- +70 / -70
- Vertical Viewing Angle
- +65 / -60
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- HID Compliant, scratch-resistant
- Black
- 35.1 cm x 20.2 cm x 30.65 cm - with stand
- 4.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA (HD-15) , DVI-D , USB (Type B) , Audio line-in (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Driver
- Dimensions & Weight Details
- Without stand - width: 35.1 cm - depth: 5.45 cm - height: 27.6 cm , With stand - width: 35.1 cm - depth: 20.2 cm - height: 30.65 cm - weight: 4.5 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
