ProLite T1531SR is based on the latest 5 wire resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with Touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90 degree angles. Extensive touch utilities allow for 4 point calibration and either 9/25 point linerization.
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
Touch technology - resistive
5-wire resistive touchscreens are very durable and can be used in a variety of environments. They are especially recommended for shops, restaurants and industrial purposes. -
IP54
The IP Code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
- iiyama ProLite T1531SR-B3 - LED monitor - 15"
- LED-backlit LCD monitor - 15" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Black
- 35.1 cm x 20.1 cm x 30.6 cm
- 4.8 kg
- VCCI, DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 15"
- Viewable Size
- 14.96"
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 350 cd/m²
- Brightness w/touchscreen
- 350 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 60.2 kHz
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 125
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- Black
- 4.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Resistive
- DVI , VGA , Serial , USB
Mechanical
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x serial cable , 1 x audio cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98, Microsoft Windows CE, Linux, Apple MacOS 9, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows Vista / XP / 7
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
