iiyama Prolite LH5565S-B1 55" 1920x1080 12ms VGA HDMI RCA LED LFD
Quicklinx: CW6DWS00 Mfr#: LH5565S-B1
  • 1080p
As the screen is covered with a glass layer, this technology offers great picture performance (high contrast and color accuracy) and scratch-resistance making it the ideal choice for use in public areas. Moreover, even if the screen is scratched, the touch function remains unaffected. Surface Acoustic Touchscreens are activated with finger or a special stylus.
The resistive touchscreens work with both finger and any input device which guarantees high accuracy level. The 5 wire resistive screens, do not lose calibration over time. Durable, robust design and an IP54 rated housing allow for installation in any kind of environment including industrial areas and retail.
  • Surface acoustic wave - single-touch solutions
  • Resistive - single-touch solutions
  • Optical - multi-touch solutions
    The optical touch technology does not rely on an overlay or substrate to register a touch event, so it's impossible to physically "wear out" the touchscreen. In fact you don't really have to physically touch the screen. You just need to put your finger or any kind of stylus very close to it. The optical technology ensures great picture performance. As there is no overlay or substrate on the screen the display characteristics remain virtually unaffected by the touch function.
  • Projected capacitive - multi-touch solutions
    Thanks to the glass overlay this technology is highly durable and the touch function remains unaffected even if the glass is scratched.
iiyama ProLite LH5565S-B1 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, cable ties, sticker, 2 batteries
Voltage
Energy Class
Class A
105 Watt
Power Consumption Stand by
0.5 Watt
124.75 cm x 5.35 cm x 71.8 cm
26.3 kg
Energy Class
Class A
105 Watt
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
Component, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Portrait mode, landscape mode
Design
Fanless Design
Dimensions
Without stand
124.75 cm
5.35 cm
71.8 cm
26.3 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1100:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Japanese
Daisy Chain
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , Component video input , USB , 3 x HDMI input , HDMI output , Component video output , Audio line-in , Audio input , Audio line-out , Remote control , LAN , Infrared (IrDA)
Cable ties, sticker, 2 batteries
VGA cable , HDMI cable
DDC-2B, VESA DPMS
Power supply
Input Voltage
0.5 Watt
