Enjoy the sun with the ProLite LH5510HSHB. A professional high-brightness Full HD (1920x1080) digital signage display with 2500 cd/m² for a crystal-clear image in any brightly-lit environment. Featuring a non-blackening IPS M+ LED panel for exceptional and long-lasting color and image performance and a 50% lower power consumption, the LH5510HSHB comes with a landscape and portrait orientation and 24/7 operating time, offering businesses an effective and energy-efficient solution to help capture their audience's attention in even the brightest of places.
- iiyama ProLite LH5510HSHB-B1 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Matte black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Frequency
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS-M+
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 167 Watt
- Power Consumption Stand by
- 0.5 Watt
- 124.26 cm x 7.43 cm x 71.36 cm
- 37.5 kg
- Product Type
- Energy Class
- Class C
- 167 Watt
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS), brightness sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design
- 124.26 cm
- 7.43 cm
- 71.36 cm
- 37.5 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- IPS-M+
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- 60 Hz Frequency
- LED backlight
- Image Contrast Ratio
- 1000:1
- Brightness
- 2500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 9 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish
- Designed for 24/7 operation
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
- VESA Compatibility
- Connector Type
- VGA input , DVI-D input , HDMI input , DisplayPort input , RS-232 input , Audio input , Speakers output
- Cables Included
- HDMI cable - 1.8 m , Serial cable - 2.5 m , Sensor cable
- DDC-2B, CB, WEEE, REACH, TUV Bauart, ERP, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0 °C
- 50 °C
