The ProLite merges the versatility and freedom of an Android OS display with the flexibility of a landscape and portrait orientation to bring you a well-rounded digital signage display you can easily customize to your needs by installing applications directly to it. It features an IPS panel, Full HD resolution, a continuous 24/7 operating time, a media player and a full range of connectors - VGA, DVI, HDMI and DisplayPort. Daisy Chain function makes the screen suitable for use in a wide variety of environments and set-ups including video walls.
Daisy chain support
Daisy chain is a connection scheme in which several devices are connected in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices via a cable. The signal output is connected to the signal input of the next device. The connection with only one cable between two devices ensures a simple and tidy installation. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
24/7
24/7 displays are designed for a continuous operation. -
Media player LFD
Play your favorite music and show your most beautiful videos, photos and images directly on screen from a flash drive or internal memory with the built-in media player.
- iiyama ProLite LH4946HS-B1 49" Class (48.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 49"
- Diagonal Size
- 48.5"
- Commercial Use
- Yes - digital signage
- Matte black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Supported Memory Cards
- microSD
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- 65.7 Watt
- Power Consumption Stand by
- 0.5 Watt
- 109.76 cm x 4.55 cm x 63.39 cm
- 15.6 kg
- Product Type
- Energy Class
- Class A+
- 65.7 Watt
- Diagonal Class
- 49"
- Diagonal Size
- 48.5"
- Commercial Use
- Operating System
- Android OS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design, Thin Bezel Design
- 109.76 cm
- 4.55 cm
- 63.39 cm
- 15.6 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 1100:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
- Backlight Life
- 50,000 hour(s)
- Anti-image retention, Daisy Chain, picture in picture (no tuner), designed for 24/7 operation
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Media Player
- microSD
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , DVI-D input , 2 x HDMI input , DisplayPort input , RS-232 input , LAN , Infrared input , Audio input , Audio output , DVI-D output , DisplayPort output , Speakers output , RS-232C output , USB 2.0
- Cables Included
- HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , DVI cable , Serial cable
- Plug and Play, DDC-2B, CB, REACH, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 129.2 cm
- Depth (Shipping)
- 20.3 cm
- Height (Shipping)
- 88.3 cm
- 0 °C
- 40 °C
