ProLite LH4265S is a 42'' Full HD, professional and fan-less LED-backlit display. Incorporating AMVA3 panel technology, the display guarantees great viewing from all angles, high brightness and exceptional color clarity. It features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. A wide range of video and audio inputs ensures compatibility with multiple platforms. Landscape and portrait friendly, ProLite LH4265S is prepared for easy installation using the VESA wall mount and daisy chain support. A perfect solution for a massive range of applications including public signage, retail, exhibitions and conference centers, POS/POI, control rooms and production facilities.
AMVA3 technology
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
USB playback
The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory. -
Light sensor
The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light. -
LAN control
LAN control enables making adjustments in the display OSD menu through a web interface.
- iiyama ProLite LH4265S-B1 42" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, cable ties, batteries, logo sticker
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 72 Watt
- Power Consumption (On mode)
- 72.2 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 105 kWh
- 96.05 cm x 5.75 cm x 55.35 cm
- 18.4 kg
- Product Type
- Energy Class
- Class B
- 72 Watt
- 72.2 W
- 105 kWh
- Diagonal Class
- 42"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- 96.05 cm
- 5.75 cm
- 55.35 cm
- 18.4 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 3000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6.5 ms
- Display Menu Language
- Czech, English, German, French, Polish, Russian, Dutch, Japanese
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- VGA input , 3 x HDMI input , Component video input , Composite video input , Audio line-in , Audio input , Audio output , Serial input , Serial output , LAN , Composite video output , Infrared input , Infrared output , Speakers output , 2 x USB 2.0
- Cable ties, batteries, logo sticker
- Cables Included
- VGA cable , HDMI cable
- VESA DPMS, CB, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
