See the difference with the ProLite LE5040UHS, a professional digital signage display with 4K graphics, 18/7 operating time and landscape orientation. Featuring a slim bezel and an AMVA3 LED panel for exceptional color and image performance and iiSignage, iiyama's free signage content creation and management software, the LE5040UHS offers businesses an easy and effective solution to help capture their audience's attention.
UHD resolution
UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image. -
AMVA3 technology
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
iiSignage
With iiSignage, you can easily create, publish and manage your own digital signage content on any iiyama 40-series display from a desktop PC in the same network. Use rich content like video's and widgets to create highly impactful advertising in minutes and schedule your content across multiple displays to best match your customers' behavior.
- iiyama ProLite LE5040UHS-B1 50" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 50"
- Commercial Use
- Yes - digital signage
- Matte black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Supported Memory Cards
- microSD
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class G
- 140 Watt
- Power Consumption (On mode)
- 121 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 183 kWh
- Dimensions (WxDxH) - without stand
- 112.35 cm x 6.8 cm x 64.65 cm
- 12.6 kg
- Product Type
- Energy Class
- Class G
- 140 Watt
- 121 W
- Power Consumption SDR (On mode)
- 121 kWh/1000h
- 183 kWh
- Diagonal Class
- 50"
- Commercial Use
- Operating System
- Android OS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Landscape mode
- Design
- Thin Bezel Design
- Cooling System
- Fanless
- Dimensions
- Without stand
- 112.35 cm
- 6.8 cm
- 64.65 cm
- 12.6 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- Operation Hours / Days
- 18 / 7
- Anti Image Retention Circuitry (AIR), Iiyama iiSignage preinstalled
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- microSD
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Streaming media playback
- Connectivity
- LAN
- Connector Type
- VGA input , 2 x HDMI input , DVI-D input , Audio input , Serial input , LAN , Infrared input , Audio output , Infrared output , USB 2.0 , USB 3.0
- Batteries
- Cables Included
- DVI cable , HDMI cable , Serial cable
- Plug and Play, DDC-2B, CB, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0 °C
- 40 °C
