The ProLite LE4041UHS is an excellent 4K (3840 x 2160) monitor, offering a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch) the monitor displays an incredibly sharp and crisp image. The VA panel technology offers exceptional color performance, high contrast (5000:1) and wide viewing angels. The display supports PIP function, which allows users to watch images coming from different sources.
4K
UHD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image. -
MVA
MVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
PIP
PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time.
- iiyama ProLite LE4041UHS-B1 40" Class (39.5" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 40"
- Diagonal Size
- 39.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- MVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 100/240 V (50/60 Hz)
- Energy Class
- Class B
- 61 Watt
- Power Consumption (On mode)
- 64.4 W
- Energy Consumption per Year
- 94 kWh
- Dimensions (WxDxH) - without stand
- 92.15 cm x 6.95 cm x 52.85 cm
- 15.6 kg
- Product Type
- Energy Class
- Class B
- 61 Watt
- 64.4 W
- 94 kWh
- Diagonal Class
- 40"
- Diagonal Size
- 39.5"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Landscape mode
- Design
- Metal frame
- Dimensions
- Without stand
- 92.15 cm
- 6.95 cm
- 52.85 cm
- 15.6 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- MVA
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Colour Depth
- 1 billion colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 12000000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.229 x 0.255mm
- Response Time
- 4 ms
- Display Menu Language
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 12 Watt
- Speakers
- 2 x main channel speaker - 6 Watt
- Connector Type
- 2 x HDMI , DVI-D input , VGA input , DisplayPort input , DisplayPort output , Audio line-in , Audio line-out , Serial input , Serial output
- Cables Included
- VGA cable , DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , Serial cable , Audio cable
- DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
- Power Device
- Power supply
- Input Voltage
- On / Off Switch
