ProLite LE3240S is a 32'' Full HD, professional and fan-less LED-backlit display. Incorporating the latest Commercial Grade IPS panel technology, the display guarantees great viewing from all angles, high brightness and exceptional color clarity. A wide range of video and audio inputs ensures compatibility with multiple platforms. ProLite LE3240S is prepared for easy installation using the VESA wall mount. This display will suit a massive range of applications including public signage, retail, exhibitions and conference centers, POS/POI, control rooms and production facilities.
USB playback
The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; 60% more in comparison to a 1280 x 1024 monitor. -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
- iiyama ProLite LE3240S-B1 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Pixel Shift
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 100/240 V (50/60 Hz)
- Energy Class
- Class B
- 42 Watt
- Dimensions (WxDxH) - without stand
- 72.65 cm x 6.35 cm x 42.52 cm
- 5.2 kg
- Product Type
- Energy Class
- Class B
- 42 Watt
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Landscape mode, Eco mode
- Pixel Shift
- Timer Functions
- Sleep
- Dimensions
- Without stand
- 72.65 cm
- 6.35 cm
- 42.52 cm
- 5.2 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1400:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.364 x 0.364mm
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm, 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- HDMI input , DVI-D input , VGA input , Component video input , Audio line-in , Audio line-in , Audio line-out , Serial input , Serial output , Remote control input , Remote control output , LAN , USB 2.0
- Cables Included
- VGA cable , DVI cable , Serial cable
- DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- On / Off Switch
- Auto On/Off
- WOL (Wake on LAN)
