iiyama ProLite E2783QSU-B1 27" 2560x1440 1ms DVI HDMI DisplayPort LED Monitor
Quicklinx: FJ0XWS00 Mfr#: E2783QSU-B1
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£191.68 ex VAT
£230.01 inc VAT
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • ACR
  • Overdrive on/off
  • Flicker free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
iiyama ProLite E2783QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
43 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
62.25 cm x 21.8 cm x 44.6 cm
4.5 kg
TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B
3-year warranty
Display Type
Energy Class
Class B
62 kWh
43 W
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
50 - 70 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
4.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DVI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable
44 Watt
Limited warranty - 3 years - on-site
iiyama ProLite E2783QSU-B1 27 Bundle deal on iiyama ProLite E2783QSU-B1 27" 2560x1440 1ms DVI HDMI DisplayPort LED Monitor
£290.85
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
