Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Overdrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Flicker free + blue light
The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
- iiyama ProLite E2783QSU-B1 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 62 kWh
- Power Consumption (On mode)
- 43 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, DisplayPort
- Tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.25 cm x 21.8 cm x 44.6 cm
- 4.5 kg
- TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 62 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 50 - 70 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
- Black
- 4.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , DVI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable
- Input Voltage
- 43 W
- Power Consumption (Typical)
- 44 Watt
- Limited warranty - 3 years - on-site
Accessories (2)
iiyama Dual Screen Desk Top Stand | In Stock | £36.76 |
iiyama Gas Spring Mounting Arm | In Stock | £36.76 |
Other bundles (1)
iiyama Dual Screen Desk Top Mounting Arm | In Stock | £23.69 |
