iiyama ProLite E2483HSU-B5 24" 1920x1080 1ms VGA HDMI LED Monitor
Quicklinx: FSFRWS00 Mfr#: E2483HSU-B5
The ProLite E2483HSU is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1 ms response time and 80 000 000: 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast.
TN LCD TECHNOLOGY
TN LCD is a great all round display technology, providing some of the fastest response times on the market, as well as delivering a vibrant and sharp image.
FLICKER FREE + BLUE LIGHT
The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
OverDrive On/Off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
SPEAKERS AND HEADPHONES
Playing with friends? Use the integrated high-quality speakers. Don’t want to disturb anybody? Plug your headset into the headphone socket and turn the volume up.
  • Flicker-free + blue light
  • OverDrive on / off
  • ACR
iiyama ProLite E2483HSU-B5 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/368808
Energy Class
Class E
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
18.1 W
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC, 99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
Voltage
56.5 cm x 18.7 cm x 41.4 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TUV GS, DDC-2B, PSE Mark, VCCI Class B, EAC, CU, REACH SvHC
3-year warranty
Display Type
Energy Class
Class E
28 kWh
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC, 99% sRGB
Response Time
1 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31 - 85 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
HDCP, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, 72% NTSC colour gamut, 99% sRGB colour gamut
3.4 kg
Audio
Speakers - stereo
Output Power / Channel
1 watt
VGA , DisplayPort , HDMI , Headphones , 2 x USB 2.0
Mechanical
Tilt
Tilt Angle
-3.5/+21.5
VESA Mounting Interface
100 x 100 mm
1 x USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
18.1 W
18.1 kWh/1000h
Power Consumption (Typical)
18 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.5 watt
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years - on-site
