Prolite C1911S-3 is a 19" LED-backlit LCD display designed for demanding CCTV and broadcast applications. The 19" CCTV display features a fast 5 m/s response time and a 1000:1 contrast ratio offering great color performance with clear and vivid images. This CCTV is also a real eco-friendly product using LED-backlight which reduces the typical power consumption.
CCTV
This CCTV monitor is designed for demanding CCTV and broadcast applications. VESA compliance allows for easy installation in any surveillance and security environment. -
LED-backlight
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
- iiyama ProLite C1911S-3 LCD display
- LCD display
- Recommended Use
- Surveillance system
- Supported Image Aspect Ratio
- 5:4
- Colour Support
- Display Size
- 19"
- Resolution
- 1280 x 1024
- LCD Technology
- TFT active matrix
- Built-in Speakers
- 2 speakers
- Black
- Voltage Required
- AC 120/230 V
- Power Consumption
- 19 Watt
- 2 years
- LCD display
- 40.7 cm
- 20.1 cm
- 43.2 cm
- 3.9 kg
CCTV
- Equipment Category
- CCTV monitors
Security DVR
- Image Resolution
- 1280x1024
Studio & Field Monitors
- Recommended Use
- 5:4
- Colour Support
- Display Size
- 19"
- Native Resolution
- 1280 x 1024
- LCD Technology
- TFT active matrix
- Built-in Speakers
- 2 speakers
- Voltage Required
- AC 120/230 V
- Frequency
- 50/60 Hz
- Power Consumption
- 19 Watt
- Black
Terminals
- Terminals
- (1) x VGA input - 15 pin HD D-Sub (HD-15) , (1) x audio line-in , (2) x composite video output - BNC , (2) x composite video input - BNC
- Warranty
- 2 years
