iiyama ProLite B2888UHSU-B1 28" 3860x2160 1ms VGA DVI HDMI DisplayPort LED Monitor
Quicklinx: B1JJWS00 Mfr#: B2888UHSU-B1
Featuring 4K (3840 x 2160) resolution, the B2888UHSU offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. PIP and PBP features allow users to easily create their own work space by displaying and manipulating multiple applications from two different data sources.
The high quality TN matrix with 10bit color processing guarantees high performance with consistent color reproduction and a fast response time. The B2888UHSU is perfect for demanding users who settle only for the best results.
  • 4K
    UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • Overdrive On / Off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • LED-Backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • HDMI
    HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
  • HAS
    A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
iiyama ProLite B2888UHSU-B1 - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
68 kWh
Power Consumption (On mode)
46.4 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, 2xDisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
Voltage
66.3 cm x 23 cm x 41.2 cm
7.7 kg
VESA DPMS, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class C
68 kWh
Diagonal Size
28"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
24 - 140 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
Picture in picture, picture by picture, HDCP, Eco-Mode, Overdrive technology, Wide Colour Gamut-CCFL, Advanced Contrast Ratio (ACR)
7.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , DVI-D , USB , Headphones , 2 x DisplayPort , HDMI , MHL / HDMI
Mechanical
Tilt Angle
17
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x Mini DisplayPort cable , 1 x USB cable , 1 x audio cable
Power Supply
Internal
Input Voltage
46.4 W
Power Consumption (Typical)
34.5 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
