The ProLite B2280HS is a high specification 22'‘ Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 2ms response time and 12 000 000 : 1 Advanced Contrast Ratio make the B2280HS ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. Triple Input support of Analog, DVI and DisplayPort ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star certified.
Overdrive On / Off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
ACR (Advanced Contrast Ratio)
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
- iiyama ProLite B2280HS-B1DP - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2482 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.95 cm x 24.45 cm x 39.3 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, DDC-2B, VESA DPMS
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2482 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +88 / -88
- Vertical Viewing Angle
- +85 / -85
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color
- Black
- 5.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- DVI-D , VGA , Audio line-in , DisplayPort (HDCP)
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DisplayPort cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
Sustainability Information
- ENERGY STAR Certified
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £30.34 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
