iiyama ProLite B2280HS 22" 1920x1080 5ms HDMI DVI-D VGA White LED Monitor with Speakers
Quicklinx: 8W99WS00 Mfr#: B2280HS-W1
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£101.86 ex VAT
£122.23 inc VAT
The ProLite B2280HS is a high specification 21.5" Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 5msec black-to-black response time and 5 000 000:1 Advanced Contrast Ratio make the B2280HS ideal for Video Conferencing, DTP and CAD as well as the usual text based applications. Triple Input support of Analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star Certified.
  • Has + pivot
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Excellent speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen.
Display Type
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
23.8 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2482 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
White
50.95 cm x 24.45 cm x 39.3 cm
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , VGA , Audio line-in , HDMI (HDCP)
Mechanical
Display Position Adjustments
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand, cable management cover
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Plug and Play, TUV GS, DDC-2B, VESA DPMS
Power Supply
Internal
21 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Environmental Standards
ENERGY STAR Certified
iiyama ProLite B2280HS 22 Bundle deal on iiyama ProLite B2280HS 22" 1920x1080 5ms HDMI DVI-D VGA White LED Monitor with Speakers
£201.03
8W99 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8W99 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.65
8W99 C2G 5m Select High Speed HDMI with Ethernet In Stock £22.20
8W99 C2G 10m Select High Speed HDMI with Ethernet In Stock £42.63
8W99 C2G 15m Select High Speed HDMI with Ethernet In Stock £57.72
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
