The 19" ProLite B1980SD designed for business usage is a LED-backlit monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. The 5 ms response time and high contrast make the B1980SD ideal for a wide range of business applications. sRGB and gamma correction functions permit even the finest nuances of color to be set accurately.
Height Adjustable Stand
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
Advanced Contrast Ratio
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
PIVOT
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
- iiyama ProLite B1980SD-W1 - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Class
- Class E
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 41.1 cm x 24.45 cm x 42.65 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VESA DPMS, VCCI Class B
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +75 / -85
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- White
- 5.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management clip
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption SDR (On mode)
- 14.5 kWh/1000h
- Power Consumption (Typical)
- 16 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
