iiyama LH9852UHS-B1 98" 3840 X 2160 LED VGA DVI HDMI 8ms
Quicklinx: FZW0WS00 Mfr#: LH9852UHS-B1
Video Interface: Composite, Component, HDMI
TV Tuner Presence: No
£7,370.59 ex VAT
£8,844.70 inc VAT
See the difference with the ProLite LH9852UHS. A professional 98-inch (248 cm) digital signage display with 4K graphics, continuous operating time (24/7) and landscape/portrait orientation. Featuring a slim bezel and an S-IPS LED panel for exceptional color and image performance, the LH9852UHS offers businesses a versatile and effective solution to help capture their audience's attention. The LH9852UHS-B1 comes with a DisplayPort Video OUT with Daisy Chain making this display a great alternative to a video wall consisting of multiple smaller displays. It can be operated via a LAN network or RS232 or via an OPS plug-in PC.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • OPS PC slot
    Build in expansion slot supports the Open Pluggable Specification (OPS) standard; it simplifies the installation of a plug-in PC for digital signage applications.
  • LAN control
    LAN control enables making adjustments in the display OSD menu through your network.
iiyama ProLite LH9852UHS-B1 98" Class (97.52" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/378012
Diagonal Class
98"
Diagonal Size
97.52"
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Frame Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15), DisplayPort
S-IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Open Pluggable Standard (OPS) support
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
Energy Class
Class G
334.4 Watt
Power Consumption (On mode)
334 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
488 kWh
219.32 cm x 8.85 cm x 124.82 cm
91.4 kg
Energy Class
Class G
334.4 Watt
334 W
334 kWh/1000h
488 kWh
Diagonal Class
98"
Diagonal Size
97.52"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design, Ultra Slim Metal Bezel Design
Dimensions
Without stand
219.32 cm
8.85 cm
124.82 cm
91.4 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
S-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Frame Rate
LED backlight
Image Contrast Ratio
1300:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
Anti Retention, Daisy Chain, picture in picture (no tuner), designed for 24/7 operation
Stands & Mounts
Flat Panel Mount Interface
800 x 500 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
VGA input , Component video input , Composite video input , 3 x HDMI input , DisplayPort input , LAN , 2 x audio line-in , RS-232C input , Remote control , Audio output , Audio output , USB 2.0 , Daisy chain output , Digital audio output (optical)
Batteries
DVI cable , HDMI cable , Mini DisplayPort-DisplayPort cable , DisplayPort cable , Serial cable
Plug and Play, DDC-2B, CB, TUV Bauart, EAC
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
250.3 cm
Depth (Shipping)
45 cm
Height (Shipping)
156.9 cm
Video Interface: Component
Video Interface: HDMI
Brand: iiyama
Price Range Ex VAT: £1500+
