iiyama LH5580S 55" 1920x1080 VGA DVI-D HDMI LED Large Format Display
Quicklinx: 99N5WS00 Mfr#: LH5580S-B1
  • 1080p
Full HD professional, feature-rich and robust, Iiyama's large format screen is designed in 55" sizes and with or without multi-touch functionality. The displays offer an exceptional capacity within retail, education, training, corporate and B2B markets. Incorporating the IPS panel technology, the display guarantee high brightness, exceptional color clarity and great viewing from all angles. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. An ambient light sensor delivers exceptional performance with the added benefit of saving on power. Landscape and portrait friendly, the display can be mounted according to the application for true impact in interactive digital signage.
  • PIP
    PIP (Picture in picture) function allows you to watch images coming from two different sources at the same time.
  • InfraRed
    The series of InfraRed touch screens 55''offer the fastest and most accurate touch response possible on LFD screens. The added benefit includes 2 point touch capability and more robust performance for even the toughest environments.
  • Portrait/landscape
    The entire 5580" LED offers the ability to be used in either portrait or landscape mode for all signage environments, allowing for high impact digital signage configurations.
iiyama ProLite LH5580S-1 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Voltage
Energy Class
Class A
133 Watt
Power Consumption (On mode)
102.6 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
150 kWh
124.7 cm x 6.65 cm x 71.8 cm
28.5 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class A
133 Watt
102.6 W
150 kWh
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
124.7 cm
6.65 cm
71.8 cm
28.5 kg
Enclosure Colour
Display
LCD Display Technology
AMVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
VGA input , S-Video input , Composite video input , Audio line-in , DVI-D input , 2 x HDMI input , DisplayPort input , Audio output , Speakers output , Composite video output , LAN , Serial output , Serial input , Speakers output , DVI-D output , 2 x USB 2.0
VGA cable , DVI cable
VESA DPMS, CB, TUV Bauart, EAC
Sustainability Information
ENERGY STAR Certified
Power supply
Input Voltage
1 Watt
