Full HD professional, feature-rich and robust, Iiyama's large format screen is designed in 55" sizes and with or without multi-touch functionality. The displays offer an exceptional capacity within retail, education, training, corporate and B2B markets. Incorporating the IPS panel technology, the display guarantee high brightness, exceptional color clarity and great viewing from all angles. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. An ambient light sensor delivers exceptional performance with the added benefit of saving on power. Landscape and portrait friendly, the display can be mounted according to the application for true impact in interactive digital signage.
PIP
PIP (Picture in picture) function allows you to watch images coming from two different sources at the same time. -
InfraRed
The series of InfraRed touch screens 55''offer the fastest and most accurate touch response possible on LFD screens. The added benefit includes 2 point touch capability and more robust performance for even the toughest environments. -
Portrait/landscape
The entire 5580" LED offers the ability to be used in either portrait or landscape mode for all signage environments, allowing for high impact digital signage configurations.
- iiyama ProLite LH5580S-1 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- AMVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 133 Watt
- Power Consumption (On mode)
- 102.6 W
- Power Consumption Stand by
- 1 Watt
- Energy Consumption per Year
- 150 kWh
- 124.7 cm x 6.65 cm x 71.8 cm
- 28.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class A
- 133 Watt
- 102.6 W
- 150 kWh
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- 124.7 cm
- 6.65 cm
- 71.8 cm
- 28.5 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6.5 ms
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- VGA input , S-Video input , Composite video input , Audio line-in , DVI-D input , 2 x HDMI input , DisplayPort input , Audio output , Speakers output , Composite video output , LAN , Serial output , Serial input , Speakers output , DVI-D output , 2 x USB 2.0
- Cables Included
- VGA cable , DVI cable
- VESA DPMS, CB, TUV Bauart, EAC
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
- 1 Watt
