The G-MASTER Red Eagle gives true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering response time, ensuring fluid and accurate transition between the images.
Custom gaming modes
Have it your way. Choose one of the predefined gaming modes or set and memorize your own settings. -
Fast response time
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance -
Black tuner
The users can adjust the brightness and the dark shades with the black tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier. -
High-quality speakers
Enjoy using the integrated high-quality speakers. Or plug your headset to the headphone socket and turn up the volume.
- iiyama G-MASTER Red Eagle GB2788HS-B2 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 49 kWh
- Power Consumption (On mode)
- 34 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.35 cm x 23 cm x 41.2 cm
- 6.9 kg
- DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
- Display Type
- Energy Class
- Class B
- 49 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 145 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Japanese
- HDCP, Eco-Mode, Overdrive technology, game mode, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, Black Tuner
- Black
- 6.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2.5 Watt
- DisplayPort , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
- Tilt Angle
- 17
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x DisplayPort cable - DisplayPort to DisplayPort
- Input Voltage
- 34 W
- Power Consumption (Typical)
- 35 Watt
