Capable of displaying Full HD images at 75 Hz, the 27'' Black Hawk G-MASTER GB2730HSU-B1 is the perfect companion in your gaming adventures. Armed with the Black Tuner function and FreeSync Technology with a stunning 1ms response time, the Black Hawk guarantees you will see every tiny detail even in the shadowed screen areas and will be able to respond to the changing situation in an instant. The height adjustable stand with pivot, swivel and tilt functions allows you to perfectly adjust the position of the screen to your preferences. So get comfortable and get in the game!
1ms response time
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance. -
The users can adjust the brightness and the dark shades with Black Tuner, giving greater viewing performance in shadowed areas and helping spot the enemy earlier. -
Predefined and custom gaming modes
Have it your way! Choose one of the predefined gaming modes (including FPS and strategy) or set and memorize your own settings.
- iiyama G-MASTER Black Hawk GB2730HSU-B1 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/361951
- Energy Class
- Class E
- Power Consumption (On mode)
- 19.3 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 61.35 cm x 23 cm x 39.75 cm
- 6.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, CU
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 40 - 75 Hz
- Horizontal Refresh Rate
- 30 - 84 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, Black Tuner, 3 gaming modes
- Matte black
- 61.35 cm x 23 cm x 39.75 cm - with stand
- 6.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DisplayPort , HDMI , Headphones (mini-jack) , 2 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B) , Audio line-in (mini-jack)
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable ¦ 1 x USB cable
- Input Voltage
- 19.3 W
- Power Consumption SDR (On mode)
- 19.3 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
