iiyama Gas Spring Mounting Arm Dual
Quicklinx: D1BNWS00 Mfr#: DS3002C-B1
Accessory Type: Monitor/desktop stand
28 In Stock
£55.73 ex VAT
£66.87 inc VAT
The iiyama DS3002C-B1 is a desk mount (grommet or clamp) for two flat screens up to 27". Using the arm you save space on your desk and thanks to the cable management system it is easier to keep your workplace tidy. But what is more important, offering broad adjustment capabilities including tilt, swivel, height and rotation, the dual gas spring arm makes sure you can easily adjust the position of the screens to your preferences assuring ergonomic body posture.
  • Effortless adjustability
    Featuring an adjustable arm with a 360° pan and a 90° rotation capability, this mounting kit allows for easy viewing angle adjustments, ensuring optimal visibility and comfort during use.
  • Versatile compatibility
    With support for 10"-27" monitors and a flat panel mount interface of 100 x 100 mm and 75 x 75 mm, this mounting kit offers broad compatibility, accommodating a wide range of display sizes and models.
  • Enhanced ergonomics
    The gas spring lift and the tilt range of -85° to 15° provide smooth and effortless adjustments, allowing users to find their perfect viewing angle, which can help reduce neck and eye strain.
  • Integrated cable management
    Keeps cables neatly organized and out of sight, contributing to a cleaner and more organized workspace, free from the clutter of wires and cables.
  • Sturdy and secure
    Designed to hold two monitors with a weight range of 1.5 kg to 5 kg each, ensuring a stable and secure setup for your displays on any desk-mountable surface.
Iiyama DS3002C-B1 mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desk-mountable
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Recommended Use
2 monitors
Recommended Display Size
10"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
5-year warranty
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desk-mountable
Cable Management
10"-27"
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Max Load Weight
5 kg
Min Load Weight
1.5 kg
Details
Gas spring lift
Limited warranty - 5 years
Brand: iiyama
