iiyama Gas Spring Mounting Arm Dual
Quicklinx: D1BNWS00 Mfr#: DS3002C-B1
Accessory Type: Monitor/desktop stand
£55.99 ex VAT
£67.18 inc VAT
The iiyama DS3002C-B1 is a desk mount (grommet or clamp) for two flat screens up to 27". Using the arm you save space on your desk and thanks to the cable management system it is easier to keep your workplace tidy. But what is more important, offering broad adjustment capabilities including tilt, swivel, height and rotation, the dual gas spring arm makes sure you can easily adjust the position of the screens to your preferences assuring ergonomic body posture.
Iiyama DS3002C-B1 mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desk-mountable
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Recommended Use
2 monitors
Recommended Display Size
10"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
5-year warranty
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
10"-27"
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Max Load Weight
5 kg
Min Load Weight
1.5 kg
Details
Gas spring lift
Limited warranty - 5 years
Brand: iiyama
