iiyama Gas Spring Mounting Arm
Quicklinx: D1BMWS00 Mfr#: DS3001C-B1
Accessory Type: Mount
20 In Stock
£36.76 ex VAT
£44.11 inc VAT
The iiyama DS3001C-B1 is a desk mount (grommet or clamp) for flat screens up to 27". Using the arm guarantees you gain additional space on your desk and the cable management system helps to keep the workplace tidy. But more importantly, offering broad adjustment capabilities including tilt, swivel, height and rotation, the arm makes sure you can easily adjust the screen position to your preferences assuring ergonomic body posture.
  • Flexible positioning
    With a 360° pan, 90° rotation, and a tilt range of -85° to 15°, this mounting kit offers flexibility in positioning your monitor for the perfect viewing angle.
  • Easy installation
    The DS3001C-B1 comes with integrated cable management and a gas spring lift, ensuring a clean setup and easy adjustment.
  • Versatile compatibility
    Supporting monitors from 10" to 27" and compatible with both 100 x 100 mm and 75 x 75 mm flat panel mount interfaces, this mounting kit is designed for a wide range of displays.
  • Secure mounting
    Designed to be desk-mountable, this mounting kit ensures your monitor stays securely in place, supporting weights from 1.5 kg to 5 kg.
Iiyama DS3001C-B1 mounting kit - adjustable arm - for Monitor - black
Mounting kit (adjustable arm) - desk-mountable
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Recommended Use
Monitor
Recommended Display Size
10"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
5-year warranty
ProLite E2783QSU-B1, XU2495WSU-B1
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
10"-27"
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Max Load Weight
5 kg
Min Load Weight
1.5 kg
Details
Gas spring lift
Limited warranty - 5 years
Iiyama ProLite E2783QSU-B1, XU2495WSU-B1
Brand: iiyama
