iiyama G-Master GB2760QSU-B1 27" 2560x1440 1ms VGA HDMI Height Adjusable
Quicklinx: CY6CWS00 Mfr#: GB2760QSU-B1
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£238.60 ex VAT
£286.32 inc VAT
G-MASTER GB2760QSU-B1 Red Eagle – join the PRO squad Whether you already are or are aiming to be a hardcore gamer, the 27’’ G-MASTER GB2760QSU known as Red Eagle is the competitive edge you need to be able to unleash your full gaming potential. Armed with FreeSync technology, 144Hz refresh rate and a blistering 1ms response time you can make split second decisions and forget about ghosting effects or smearing issues. The WQHD (2560x1440) display offers 77% more on-screen space than a standard 1920x1080 full HD monitor. The ability to adjust brightness and the dark shades with the Black Tuner delivers greater viewing performance in shadowed areas. Nothing will skip your attention. Triple input setup (DVI, HDMI, DisplayPort), speakers, headphone connector and a 3.0 USB hub are all included. So no matter which you prefer: RTS, FPS, MOBA and MMO – with the Red Eagle on your desk you are top of the gamer community food chain.
  • 144 Hz
    Rapid refresh rate and frame rate guarantee smooth, blur free and judder free graphics, with lower latency and lag improving response times for fast paced games. Especially suited to the fast pace games like FPS, racers, MOBA and sports where the 144 Hz refresh rate delivers the crisp and sharp images needed to raise your game.
  • FreeSync technology
    AMD FreeSync technology puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
  • QHD
    With the 2560 x 1440 QHD resolution offering 77% more on-screen space than a standard 1920 x 1080 full HD monitor, nothing skips your attention.
  • Predefined and custom gaming modes
    Have it your way! Choose one of the predefined gaming modes (including FPS and strategy) or set and memmorize your own settings.
iiyama G-MASTER Red Eagle GB2760QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40.5 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Matte
61.35 cm x 23 cm x 39.75 cm
6.4 kg
Plug and Play, TUV GS, DDC-2B, DVI DMPM, VESA DPMS, CU, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class B
59 kWh
40.5 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
48 - 144 Hz
Horizontal Refresh Rate
30 - 222 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, matte, game mode, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, brightness uniformity, i-Style Color, Black Tuner, Composite Sync, Adaptive Contrast
6.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , DisplayPort , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), adjustable height
1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable - DisplayPort to DisplayPort
AC 100/240 V (50/60 Hz)
40 Watt
Limited warranty - 3 years - on-site
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
