iiyama G-Master GB2730QSU-B1  27" 2560x1440 1ms DVI HDMI DisplayPort LED Monitor
Quicklinx: DDJTWS00 Mfr#: GB2730QSU-B1
The 27" G-MASTER GB2730QSU known as Silver Crow opens you to a whole new level of gaming experiences. As the 2560 x 1440 display offers 77% more on-screen space than a standard 1920 x 1080 Full HD monitor, the Silver Crow makes sure all the finest details are displayed with perfect image clarity. Nothing will skip your attention. The blue light reducer function along with the flicker free panel are the shield your eyes need to guarantee your vision remains well protected. Armed with FreeSync technology and 1ms response time the Silver Crow is ready to lead you into the toughest battles, leaving nothing to chance.
  • WQHD
    With the 2560 x 1440 WQHD resolution offering 77% more on-screen space than a standard 1920 x 1080 full HD monitor, nothing skips your attention.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn up the volume!
  • Predefined and custom gaming modes
    Have it your way! Choose one of the predefined gaming modes (including FPS and strategy) or set and memmorize your own settings.
iiyama G-MASTER Silver Crow GB2730QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
28.8 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 75 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
61.1 cm x 39.7 cm x 23 cm
7.2 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, CU, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class G
52 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 117 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, Black Tuner
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , DVI-D (HDCP) , HDMI (HDCP) , Headphones , Audio line-in , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable ¦ 1 x DisplayPort cable ¦ 1 x USB cable
Input Voltage
28.8 W
28.8 kWh/1000h
Power Consumption (Typical)
30 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
