The 27" G-MASTER GB2788HS known as Red Eagle is a real game changer, giving true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering 1 ms response time, ensuring fluid and accurate transition between the images.
Armed with FreeSync technology and 144Hz refresh rate, this powerful predator has no mercy for ghosting effects or smearing issues. Perfect vision manifested in the ability to adjust brightness and the dark shades with the Black Tuner delivers greater viewing performance in shadowed areas. No matter which you prefer: RTS, FPS, MOBA and MMO - choose Red Eagle and rank yourself top of the gamer community food chain.
144 Hz
Rapid refresh rate and frame rate guarantee smooth, blur free and judder free graphics, with lower latency and lag improving response times for fast paced games. Especially suited to the fast pace games like FPS, racers, MOBA and sports where the 144hz refresh rate delivers the crisp and sharp images needed to raise your game. For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI. -
FreeSync technology
AMD FreeSync technology puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate. -
1 ms
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance. -
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier. -
OverDrive On/Off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
- iiyama G-MASTER Red Eagle - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 31.6 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.277 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.8 cm x 23 cm x 38.5 cm
- 5.6 kg
- DDC-2B, PSE Mark, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- 52 kWh
- Diagonal Size
- 24"
- AMD FreeSync
- Built-in Devices
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.277 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 145 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, black level
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction
- Black
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- DVI-D , DisplayPort , 2 x HDMI , Headphones , 2 x USB 2.0 , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
- Input Voltage
- 31.6 W
- Power Consumption SDR (On mode)
- 31.6 kWh/1000h
- Power Consumption HDR (On mode)
- 60.9 kWh/1000h
- Power Consumption (Typical)
- 34 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £25.26 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
