iiyama G-Master G2730HSU-B1 27" 1ms 1920x1080 VGA HDMI Monitor
Quicklinx: CY69WS00 Mfr#: G2730HSU-B1
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£134.06 ex VAT
£160.87 inc VAT
G-MASTER G2730HSU-B1 Black Hawk – get in the game No matter if you are a newbie or an old wolf in the world of gaming, the 27’’ Black Hawk G-MASTER G2730HSU is the perfect companion at your side. Capable of displaying Full HD images at 75Hz refresh rate it will always have your back. Armed with Black Tuner function and FreeSync Technology with a stunning 1 ms response time, the Black Hawk guarantees you will see every tiny detail even in the shadowed screen areas and will be able to respond to the changing situation in an instant. Triple input support (VGA, HDMI, DisplayPort), speakers, headphone connector and a USB hub are all included. So stay in control, keep calm and get in the game! If 27'' is too big for you, check out the 24.5'' Black Hawk G2530HSU.
  • 1 ms
    Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
  • Black Tuner
    The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
  • Predefined and custom gaming modes
    Have it your way! Choose one of the predefined gaming modes (including FPS and strategy) or set and memmorize your own settings.
iiyama G-MASTER Black Hawk G2730HSU-B1 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
19.7 W
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
61.35 cm x 19.7 cm x 44.05 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, DVI DMPM, VESA DPMS, CU, VESA DDC 2 B
Display Type
Energy Class
Class A+
29 kWh
19.7 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, matte, game mode, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, brightness uniformity, i-Style Color, Black Tuner, Adaptive Contrast
5.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DisplayPort (HDCP) , Audio line-in , Headphones , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Cable holder
1 x power cable , 1 x HDMI cable , 1 x audio cable
AC 100/240 V (50/60 Hz)
19 Watt
ENERGY STAR Certified
iiyama G-Master G2730HSU-B1 27 Bundle deal on iiyama G-Master G2730HSU-B1 27" 1ms 1920x1080 VGA HDMI Monitor
£233.23
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
