iiyama G-Master 34" 21:9 Ultra Wide HA LED HDMI 3440X1440
Quicklinx: G0L5WS00 Mfr#: GB3461WQSU-B1
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort
£333.70 ex VAT
£400.44 inc VAT
With IPS panel, 144Hz refresh rate, 1ms MPRT and the 3440x1440 resolution, the monitor allows hardcore gamers to unleash their gaming potential and enjoy superb image quality. The height adjustable stand ensures you can easily adjust the screen position to your preferences and the ability to customize the screen settings using the predefined and custom gaming modes along with the Black Tuner function gives you control over the dark scenes to make sure details are always clearly visible.
  • FreeSync Premium Technology
    This monitor supports displaying HDR content and guarantees low input latency an low framerate compensation putting an end to any tearing or stuttering issues at virtually any framerate.
  • Ultra Wide - UWQHD
    UWQHD (Ultra Wide QHD) resolution offers an ultra wide (21:9) viewable area.
iiyama G-MASTER Red Eagle GB3461WQSU-B1 - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/437377
Energy Class
Class G
Energy Consumption per Year
69 kWh
Power Consumption (On mode)
39.6 W
Adaptive-Sync Technology
AMD FreeSync Premium
USB 3.0 hub
Panel Type
ADS-IPS
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 (DisplayPort: 144 Hz, HDMI: 120 Hz)
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB, 74% NTSC
Input Connectors
2xHDMI, 2xDisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Matte
Voltage
Matte black
81.7 cm x 23 cm x 41.5 cm
9.7 kg
VCCI, DDC-2B, RoHS, WEEE, PSE Mark, TUV Bauart, EAC, REACH SvHC
3-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
69 kWh
Diagonal Size
34"
Built-in Devices
USB 3.0 hub
Panel Type
ADS-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB, 74% NTSC
Response Time
Vertical Refresh Rate
15 - 144 Hz
Horizontal Refresh Rate
30 - 220 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
Picture in picture, picture by picture, HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, i-Style Color, Black Tuner, HDR Ready technology, Blue Light Reducer Function
Matte black
81.7 cm x 23 cm x 41.5 cm - with stand
9.7 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , 2 x DisplayPort , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphones (mini-jack)
Mechanical
Tilt Angle
-3/+22
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
39.6 W
39.6 kWh/1000h
Power Consumption HDR (On mode)
55.5 kWh/1000h
Power Consumption (Typical)
49 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 81.7 cm - depth: 5.85 cm - height: 36.7 cm , With stand - width: 81.7 cm - depth: 23 cm - height: 41.5 cm - weight: 9.7 kg
Shipping Width
90 cm
Shipping Depth
23 cm
Shipping Height
46 cm
Shipping Weight
12.8 kg
3-year warranty
5 °C
35 °C
10 - 80% (non-condensing)
Diagonal Size: 34in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: iiyama
