With IPS panel, 144Hz refresh rate, 1ms MPRT and the 3440x1440 resolution, the monitor allows hardcore gamers to unleash their gaming potential and enjoy superb image quality. The height adjustable stand ensures you can easily adjust the screen position to your preferences and the ability to customize the screen settings using the predefined and custom gaming modes along with the Black Tuner function gives you control over the dark scenes to make sure details are always clearly visible.
FreeSync Premium Technology
This monitor supports displaying HDR content and guarantees low input latency an low framerate compensation putting an end to any tearing or stuttering issues at virtually any framerate. -
Ultra Wide - UWQHD
UWQHD (Ultra Wide QHD) resolution offers an ultra wide (21:9) viewable area.
- iiyama G-MASTER Red Eagle GB3461WQSU-B1 - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/437377
- Energy Class
- Class G
- Energy Consumption per Year
- 69 kWh
- Power Consumption (On mode)
- 39.6 W
- Adaptive-Sync Technology
- AMD FreeSync Premium
- USB 3.0 hub
- Panel Type
- ADS-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 (DisplayPort: 144 Hz, HDMI: 120 Hz)
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey), 1 ms (MPRT)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB, 74% NTSC
- Input Connectors
- 2xHDMI, 2xDisplayPort
- Height, swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 81.7 cm x 23 cm x 41.5 cm
- 9.7 kg
- VCCI, DDC-2B, RoHS, WEEE, PSE Mark, TUV Bauart, EAC, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 69 kWh
- Diagonal Size
- 34"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- ADS-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 15 - 144 Hz
- Horizontal Refresh Rate
- 30 - 220 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
- Picture in picture, picture by picture, HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, i-Style Color, Black Tuner, HDR Ready technology, Blue Light Reducer Function
- Matte black
- 81.7 cm x 23 cm x 41.5 cm - with stand
- 9.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI , 2 x DisplayPort , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphones (mini-jack)
Mechanical
- Tilt Angle
- -3/+22
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 39.6 W
- Power Consumption SDR (On mode)
- 39.6 kWh/1000h
- Power Consumption HDR (On mode)
- 55.5 kWh/1000h
- Power Consumption (Typical)
- 49 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 81.7 cm - depth: 5.85 cm - height: 36.7 cm , With stand - width: 81.7 cm - depth: 23 cm - height: 41.5 cm - weight: 9.7 kg
- Shipping Width
- 90 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 46 cm
- Shipping Weight
- 12.8 kg
- 3-year warranty
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
