The ProLite E2278HSD is a 21,5" FHD 1920x1080 LED-backlit monitor. It features 5msec response time and >5M: 1 Advanced Contrast Ratio assuring vibrant images and blur free Video. Analog VGA and Digital DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is Energy Star qualified and VESA mount compatible. A reliable solution for both home and office use.
LED-backlight
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
- iiyama ProLite E2278HD-1 - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.45 cm x 17.75 cm x 36.95 cm
- 2.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- VCCI Class B ITE, VESA DPMS, DDC/CI, TUV Bauart
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, input select, phase, clock, luminance
- OSD Languages
- English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- Black
- 2.8 kg
- DVI-D (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Sustainability Information
- ENERGY STAR Certified
