iiyama Dual Screen Desk Top Mounting Arm
Quicklinx: D19XWS00 Mfr#: DS1002C-B1
Hurry, only 2 left in stock!
£34.72 ex VAT
£41.66 inc VAT
The iiyama DS1002C-B1 is a desk mount (clamp) for two flat screens up to 30". Thanks to the arm you can save space on your desk and the cable management system helps to keep your workplace tidy. Broad adjustment capabilities, including tilt, swivel, height and rotation, the arm offers, allow you to easily adjust the position of the screens to your preferences assuring comfortable and healthy body posture.
  • Flexible positioning
    With an adjustable arm that lifts up to 20 cm, pans 180°, and rotates 90°, this mounting kit offers flexibility in positioning your monitors for the optimal viewing experience.
  • Ergonomic design
    The DS1002C-B1 features a tilt range from -85° to 15°, allowing users to adjust their displays to the most ergonomic angles, reducing neck and eye strain during long working hours.
  • Seamless integration
    Integrated cable management ensures a tidy workspace by neatly concealing cables, enhancing productivity and maintaining a clutter-free desk.
  • Versatile compatibility
    Supporting a wide range of monitor sizes from 10" to 30" and compatible with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, this mounting kit is designed for versatility and ease of use.
Iiyama DS1002C-B1 mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desk-mountable
Tilt
-85° to 15°
Pan
180°
Lift
20 cm
Rotation
90°
Recommended Use
2 monitors
Recommended Display Size
10"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
5-year warranty
ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desk-mountable
Cable Management
10"-30"
Tilt
-85° to 15°
Pan
180°
Lift
20 cm
Rotation
90°
Max Load Weight
10 kg
Limited warranty - 5 years
Iiyama ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
Brand: iiyama
