The Prolite B2780HSU is a 27" Full HD monitor with a low power LED-backlit display. It features a stunning 2 ms Response Time, 4 Port USB Hub, a high definition 1920 x 1080 Resolution and comes with VGA, DVI and HDMI connections. The 12 000,000:1 advanced contrast ratio and 300 cd/m2 brightness offer the user clear and vivid images. The ergonomic stand offers 11 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. The Prolite B2780HSU is an excellent choice for universities, corporate, financial and design markets.
HAS + pivot
A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. -
ACR
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; 60% more in comparison to a 1280 x 1024 monitor. -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
- iiyama ProLite B2780HSU-W1 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 46 kWh
- Power Consumption (On mode)
- 31.3 W
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.3113 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 64.2 cm x 25 cm x 43.8 cm
- 8 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, VESA DPMS, TUV Bauart
- Display Type
- Energy Class
- Class B
- 46 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3113 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color
- White
- 64.2 cm x 25 cm x 43.8 cm - with stand
- 8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Audio line-in , 4 x USB 2.0 downstream , USB 2.0 upstream , Headphones
Mechanical
- Tilt Angle
- -4/+22
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Mounting Kit
- Included
- Input Voltage
- 31.3 W
- Power Consumption (Typical)
- 37 Watt
- Power Consumption Stand by
- 1 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
- Dimensions & Weight Details
- With stand - width: 64.2 cm - depth: 25 cm - height: 43.8 cm - weight: 8 kg , Without stand - width: 64.2 cm - depth: 6.5 cm - height: 39.25 cm
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
