iiyama 65" 1920x1080 8ms VGA DVI-D HDMI DP USB LED LFD
Quicklinx: BN8VWS00 Mfr#: TH6564MIS-B2AG
  • 1080p
The ProLite TH6564MIS-B2AG is the perfect solution for educational and corporate use. The high quality commercial AMVA3 LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The solid and robust design is capable of withstanding the requirements of highly-demanding environments. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The anti-glare feature drastically reduces ambient reflection in high brightness environments without compromising the sharp clarity of the content. By using a finger or stylus, you can write, annotate, draw and present with confidence.
  • IR touch technology
    The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • AMVA3
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Anti-glare coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • PIP
    PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
iiyama ProLite TH6564MIS-B2AG 65" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
AMV3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, pen stylus
Voltage
Energy Class
Class C
255 Watt
Power Consumption (On mode)
232 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
339 kWh
152.1 cm x 11.1 cm x 83.3 cm
64.1 kg
Energy Class
Class C
255 Watt
232 W
339 kWh
Diagonal Class
65"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode
152.1 cm
11.1 cm
83.3 cm
64.1 kg
Enclosure Colour
Display
LCD Display Technology
AMV3
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.744 x 0.744mm
Response Time
8 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Multitouch, infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Remote control
Audio System
Audio Controls
Balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - 12 Watt
Connector Type
VGA input , DVI-D input , HDMI input , DisplayPort input , Composite video input , S-Video input , Audio input , Audio input , Component video input , Remote control , Serial , USB , VGA output , Composite video output , Audio output
Pen stylus
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Input Voltage
0.5 Watt
0 - 85% (non-condensing)
