iiyama 42" LCD/LFD Display 1920 x 1080 DVI-D HDMI VGA USB
Quicklinx: BZKRWS00 Mfr#: TF4237MSC-B1AG
  • 1080p
With 1920x1080 Full HD resolution and Projective Capacitive 12 point touch technology, the ProLite TF4237MSC-B1AG delivers seamless and accurate touch response. Featuring an IPS Direct LED LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the display comes with a rugged bezel making it suitable for demanding environments.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Open frame
    Open frame monitors come equipped with external mounting brackets making them an ideal solution for kiosk integrators.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
iiyama ProLite TF4237MSC-B1AG 42" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, clamper
Voltage
Energy Class
Class B
100 Watt
Power Consumption (On mode)
68 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
99 kWh
97.55 cm x 8.8 cm x 57.5 cm
24 kg
Energy Class
Class B
100 Watt
68 W
99 kWh
Diagonal Class
42"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Face-up Mode
Dimensions
Without stand
97.55 cm
8.8 cm
57.5 cm
24 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4833mm x 0.4833mm
Touchpoints Qty
12
Response Time
6 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - 7 Watt
Connector Type
DVI-D input , VGA input , Audio line-in , Audio line-out , Serial input , Serial output , USB , Remote control
Clamper
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Input Voltage
0.5 Watt
On / Off Switch
No
