IcyBox 3.5" SATA HDD or SSD enclosure
Quicklinx: 6KLKWS00 Mfr#: IB-318STU3-B
IB-318StU3-B is also working through an USB 3.0 cable or USB 2.0 cable with computer/notebook with USB 2.0/1.1 interfaces. You can upgrade your computer/notebook with an USB 3.0 PCI-card.
USB 3.0 has a 10 times higher bandwidth as USB 2.0 and theoretically 10 times higher transfer rate. In practice, the transfer rate is limited by the slower SATA interface of the hard drive.
ICY BOX IB-318StU3-B - storage enclosure - SATA 3Gb/s - USB 3.0
Storage enclosure
Bus Type
USB 3.0
Expansion Bays
1 x hot-swap - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Aluminium
AC 120/230 V
Microsoft Windows 98, Linux, Apple MacOS 9.1, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows 2003
22 cm x 3 cm x 11.5 cm
410 g
Storage enclosure
3.5"
Host Bus
USB 3.0
Product Material
Aluminium
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
1
Bays
1 x hot-swap - 3.5"
1 x SATA 3Gb/s
1 x USB 3.0
Stand
1 x USB cable - external
Plug and Play
Power adapter
AC 120/230 V
24 Watt
22 cm
3 cm
11.5 cm
410 g
