IBM x3550 M3 4C E5620 2.40GHz 4GB
Quicklinx: 713NWS00 Mfr#: 7944K3G
  • Xeon
The IBM System x3550 M3 builds on the Xeon processor technology with extreme processing power and superior energy management and cooling features. With a flexible, energy-smart design that integrates low-wattage components, the x3550 M3 can help you meet demanding workloads at a lower cost per watt.
  • Robust security
    Equipped with a Trusted Platform Module (TPM 1.2) security chip, this server ensures your data is protected from unauthorized access, providing peace of mind for sensitive information.
  • High scalability
    With support for up to 2 Intel Xeon processors and 18 DIMM slots for DDR3 SDRAM, the Lenovo System x3550 M3 offers exceptional scalability, allowing for significant upgrades to meet the demands of growing businesses.
  • Versatile connectivity
    Featuring a comprehensive range of interfaces including USB 2.0, VGA, and management ports, this server offers versatile connectivity options for a wide range of peripherals and devices.
  • Efficient power management
    The hot-plug power supply, coupled with features like automatic server restart (ASR) and predictive failure analysis (PFA), ensures uninterrupted service and efficient power management for critical business operations.
Lenovo System x3550 M3 - rack-mountable Xeon E5620 2.4 GHz - 4 GB - no HDD
Server - rack-mountable - administrator password, power-on password, selectable boot, unattended boot, thermal monitoring, voltage monitoring, fan speed monitoring, predictive failure analysis (PFA), automatic server restart (ASR)
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5620 / 2.4 GHz (up to 2.66 GHz, (Quad-Core)
Processor Socket
LGA1366 Socket
Processor Main Features
Hyper-Threading Technology, Intel QuickPath Interconnect
Cache Memory
12 MB L3 Cache
Cache Per Processor
12 MB
RAM
4 GB (installed) / 144 GB (max) - DDR3 SDRAM - ECC Chipkill - PC3-10600
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x8 (ServeRAID M5014); SATA
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox MGA G200eV
Video Memory
16 MB DDR2 SDRAM
1GbE
Power Redundancy
Optional
OS Provided
No operating system
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
Stealth black
44 cm x 71.1 cm x 4.3 cm
12.7 kg
Manufacturer Selling Program
IBM Express Seller
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Stealth black
Processor / Chipset
CPU
Intel Xeon E5620
Clock Speed
2.4 GHz
Max Turbo Speed
2.66 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1366 Socket
Chipset Type
Intel 5520
Cache Memory
Installed Size
L3 Cache - 12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
18 (Total) / 17 (empty)
Registered, Memory Mirroring
Configuration Features
1 x 4 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe 2.0 x8
Controller Interface Type
Storage Controller Name
ServeRAID M5014
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
256 MB
Storage Controller (2nd)
1 x SATA - integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox MGA G200eV
Video Memory
16 MB DDR2 SDRAM
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5709C
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Maxim VSC452 Super Baseboard Management Controller with Integrated VGA Controller
Wake on LAN (WoL), PXE support, Teaming support
Bays
4 (total) / 4 (free) x hot-swap 2.5" SFF , 1 (total) / 1 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 18 (total) / 17 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 - low-profile , 1 (total) / 1 (free) x PCIe x16 - half-length, full-height
4 x USB 2.0 (2 front, 2 rear) , 2 x VGA (1 front, 1 rear) , 2 x LAN (Gigabit Ethernet) , 1 x serial , 1 x management
Administrator password, power-on password, selectable boot, unattended boot, thermal monitoring, voltage monitoring, fan speed monitoring, predictive failure analysis (PFA), automatic server restart (ASR)
NOM, ICES-003 Class A, IEC 60950-1, FCC Part 15 A
IBM Express Seller
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
675 Watt
Operating System / Software
OS Provided
No operating system
44 cm
71.1 cm
4.3 cm
12.7 kg
10 °C
35 °C
20 - 80%
713N IBM 5 YEAR ONSITE REPAIR 247 4 HOUR RESPONSE In Stock £1,546.43
713N IBM 3 Year Onsite Repair 9x5 4 Hour Response In Stock £448.81
713N IBM x3550 5 Yr On-Site 9x5x4hr Target In Stock £1,058.33
