The IBM System x3250 M3 is a single-socket server that offers new levels of performance and flexibility to help you respond quickly to changing business demands. Cost-effective and compact, it is well-suited for small to mid-sized businesses as well as large enterprises, whether for general-purpose workloads or specialized applications.
Built with the Intel Xeon series processors, the x3250 M3 has industry-leading computing capabilities in a small, 1U footprint. It also offers substantial memory and storage capacity to help you manage your data efficiently.
Amplify your performance
Built with the Intel Xeon series processors, the x3250 M3 has industry-leading computing capabilities in a small, 1U footprint. It also offers substantial memory and storage capacity to help you manage your data efficiently. -
Save on energy costs
The x3250 M3 features support for IBM Systems Director Active Energy Manager to help you monitor and control power consumption in your IT environment. -
Easy serviceability
To help you stay focused on your core business, the x3250 M3 offers easy deployment, update management and much more with its built-in IBM Tool Center. It delivers leadership reliability, management and flexibility while helping you protect your IT investments and lower your operating costs.
- Lenovo System x3250 M3 - rack-mountable Xeon X3430 2.4 GHz - 2 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, selectable boot, unattended boot, unattended start mode, thermal monitoring, voltage monitoring, fan speed monitoring, predictive failure analysis (PFA), automatic server restart (ASR)
- Height (Rack Units)
- 1U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon X3430 / 2.4 GHz (up to 2.8 GHz, (Quad-Core)
- Processor Socket
- LGA1156 Socket
- Processor Main Features
- Intel Extended Memory 64 Technology, Intel Turbo Boost Technology
- Cache Memory
- 8 MB L3 Cache
- Cache Per Processor
- 8 MB
- RAM
- 2 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-10600
- Storage Controller
- RAID (SATA 3Gb/s / SAS) (ServeRAID M1015)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox MGA G200eV
- Video Memory
- 128 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Windows Server Certified
- This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
- Raven black
- 44 cm x 55.9 cm x 4.3 cm
- 11 kg
- Manufacturer Selling Program
- IBM Express Seller
- Limited warranty - parts and labour - 3 years
- Server
- Product Form Factor
- Rack-mountable - 1U
- Built-in Devices
- Led panel
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 2
- Raven black
Processor / Chipset
- CPU
- Intel Xeon X3430
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1156 Socket
- Chipset Type
- Intel 3420
- Front Side Bus
- 1333 MHz
Cache Memory
- Installed Size
- L3 Cache - 8 MB
- 8 MB
RAM
- Installed Size
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 6 (Total) / 5 (empty)
- Mixing of different types of memory modules is not supported
- Configuration Features
- 1 x 2 GB
- RAM Supported
- PC3-10600 - 32 GB registered - ECC , PC3-10600 - 16 GB unbuffered - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card
- Controller Interface Type
- SATA 3Gb/s / SAS
- Storage Controller Name
- ServeRAID M1015
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox MGA G200eV
- Video Memory
- 128 MB
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel 82574L
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 2 (total) / 2 (free) x hot-swap 3.5" Slim Line
- Slots
- 6 (total) / 5 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe x8 - three-quarter-length, full-height , 1 (total) / 1 (free) x PCIe x8 - half-length, low-profile
- 4 x USB 2.0 (2 front, 4 rear) , 2 x LAN (Gigabit Ethernet) , 1 x serial , 1 x VGA
- Administrator password, power-on password, selectable boot, unattended boot, unattended start mode, thermal monitoring, voltage monitoring, fan speed monitoring, predictive failure analysis (PFA), automatic server restart (ASR)
- FCC Class A certified, UL, TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, EN 60950, ZH1 618, VCCI Class A ITE, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15, ICES-003 Class A, IEC 60950-1, CSA C22.2 No. 60950-1-03
- Power supply
- Voltage Required
- Power Provided
- 400 Watt
Operating System / Software
- OS Provided
- 44 cm
- 55.9 cm
- 4.3 cm
- 11 kg
IBM x3250 3 Yr On-Site 9x5x4hr Target | In Stock | £90.47 |
IBM x3250 3 Yr On-Site 24x7x4hr Target | In Stock | £171.43 |
IBM x3250 4 Yr On-Site 9x5x4hr Target | In Stock | £221.43 |
IBM x3250 4 Yr On-Site 24x7x4hr Target | In Stock | £333.33 |
IBM x3250 5 Yr On-Site 9x5x4hr Target | In Stock | £353.57 |
IBM x3250 5 Yr On-Site 24x7x4hr Target | In Stock | £521.43 |
