IBM System Storage DS3200 Dual Controller
Quicklinx: 634XWS00 Mfr#: 172622X
The IBM System Storage DS3200 external storage enclosures are designed to be an easy, scalable, flexible, and affordable solution for System x and BladeCenter servers. The DS3200 is a 3Gb external SAS storage solution that is easy to deploy and manage. Available in single and dual controller models, the DS3200 scales in capacity to support a total of 48 hard disk drives by using the EXP3000 expansion unit. The DS3200 is a direct-attach solution for System x servers, and enables small and medium businesses manage their fast-growing data capacity requirements on an affordable budget.
IBM System Storage DS3200 Model 22X - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
12 TB
SAS
0 (installed) / 12 (max)
Supported Drives
SAS
Storage Controller
RAID (SAS) - RAID 0, 1, 3, 5, 10
Storage Controller Quantity
2
Hard Drive
0 HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
Manufacturer Selling Program
IBM Express Seller
48.2 cm x 52.1 cm x 8.7 cm
27.2 kg
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SAS
Storage
12 TB
HDD Array External Interface
SAS
Storage Controller
RAID
Installed Qty
2
Interface Type
SAS
Cache / Buffer Size (Max)
512 MB
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 10
Storage Controller (2nd)
Installed Qty
2
Hard Drive
HDD - hot-swap
0
Expansion Bays
12 (total) / 12 (free) x hot-swap
TUV, VCCI, C-Tick, cUL, NOM, CB, MIC, FCC, BSMI CNS 13438
IBM Express Seller
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
48.2 cm
52.1 cm
8.7 cm
27.2 kg
Limited warranty - parts and labour - 3 years
10 °C
20 - 80%
