IBM ServeRAID-M5000 Series Battery
Quicklinx: 8LMJWS00 Mfr#: 46M0917
Lenovo ServeRAID M5000 Series Battery Kit - Memory backup battery - 1 x Lithium Ion - for ServeRAID M5014; ServeRAID M5015; System x3250 M3; x3630 M3 7377; x3650 M3; x3950 X5
  • Enhanced compatibility
    Designed specifically for PC systems, the Lenovo ServeRAID M5000 Series Battery Kit ensures seamless integration and optimal performance with compatible hardware.
  • Reliable power
    Equipped with lithium-ion technology, this battery kit provides a reliable power source for your Lenovo ServeRAID, ensuring your system remains operational and efficient.
Lenovo ServeRAID M5000 Series Battery Kit - memory backup battery - Li-Ion
50 g
Lithium Ion
Batteries Qty
1
5.4 cm x 1.6 cm x 8.3 cm
Quantity
1
Lithium Ion
5.4 cm
1.6 cm
8.3 cm
50 g
IBM ServeRAID M5014 , Lenovo ServeRAID M5015 , Lenovo System x3250 M3 , Lenovo System x3630 M3 7377 , Lenovo System x3650 M3 , Lenovo System x3950 X5
