IBM SAS Connectivity Card (CIOv) for IBM BladeCenter
Quicklinx: 6352WS00 Mfr#: 43W4068
Marketing description is not available.
  • Enhanced compatibility
    Designed specifically for PC use, the Lenovo SAS Connectivity Card (CIOv) ensures seamless integration with your computer system, providing a reliable connection that enhances your system's performance and efficiency.
  • Easy installation
    This connectivity card offers a straightforward installation process, allowing you to upgrade your system's capabilities without the need for professional assistance, making it an ideal choice for both experienced and novice users alike.
Lenovo SAS Connectivity Card (CIOv) - server 2-port SAS connectivity card
Server 2-port SAS connectivity card
1-year warranty
BladeCenter JS23 7778; JS43 7778; BladeCenter HC10 7996; HS22 7870
Limited warranty: - 1 year
10 °C
35 °C
IBM BladeCenter JS23 7778 , IBM BladeCenter JS43 7778 , Lenovo BladeCenter HC10 7996 , Lenovo BladeCenter HS22 7870
