Enhanced compatibility
Designed specifically for PC use, the Lenovo SAS Connectivity Card (CIOv) ensures seamless integration with your computer system, providing a reliable connection that enhances your system's performance and efficiency. -
Easy installation
This connectivity card offers a straightforward installation process, allowing you to upgrade your system's capabilities without the need for professional assistance, making it an ideal choice for both experienced and novice users alike.
- Lenovo SAS Connectivity Card (CIOv) - server 2-port SAS connectivity card
- Product Type
- Server 2-port SAS connectivity card
- 1-year warranty
- Designed For
- BladeCenter JS23 7778; JS43 7778; BladeCenter HC10 7996; HS22 7870
- Product Type
- Limited warranty: - 1 year
- 10 °C
- 35 °C
- Designed For
- IBM BladeCenter JS23 7778 , IBM BladeCenter JS43 7778 , Lenovo BladeCenter HC10 7996 , Lenovo BladeCenter HS22 7870
