IBM Express x3300 M4, Xeon 4C E5-2407 80W 2.2GHz 4GB
Quicklinx: 918TWS00 Mfr#: 7382E3G
  • Xeon
Powerful, flexible and reliable, the IBM System x3300 M4 is the value-priced performance tower for your emerging business.
The x3300 M4 is a scalable, easy-to-use solution for customers in need of a powerful, affordable business server that can fit under their desk. The x3300 M4 embraces the "pay as you grow" philosophy to maintain an affordable entry price while allowing you to scale and configure the server to meet your needs. This dual-socket system comes standard with a single Intel Xeon processor and room to add a second as needed.
  • Robust security
    Equipped with a Trusted Platform Module (TPM 1.2) security chip, this server ensures your data is protected from unauthorized access, providing a secure foundation for your business operations.
  • Flexible storage options
    With support for RAID 0, RAID 1, and RAID 10 configurations, the Lenovo System x3300 M4 offers flexible storage solutions to meet the varying needs of your business, ensuring data redundancy and performance.
  • High scalability
    Featuring 12 DIMM slots and support for up to 2 Intel Xeon processors, this server is designed to grow with your business, offering the scalability needed for increasing workloads and computing demands.
  • Comprehensive connectivity
    With six USB 2.0 ports located at the front and rear, along with integrated Gigabit Ethernet, this server provides ample connectivity options for a wide range of peripherals and network configurations.
  • Advanced memory features
    Supporting ECC memory and offering features like Memory Mirroring and Memory Sparing, the Lenovo System x3300 M4 ensures data integrity and reliability for critical business applications.
Lenovo System x3300 M4 - tower - Xeon E5-2407 2.2 GHz - 4 GB - no HDD
Server - tower - administrator password, power-on password, cover key lock, predictive failure analysis (PFA), automatic server restart (ASR)
Region: EMEA
Server Scalability
2-way
1 x Intel Xeon E5-2407 / 2.2 GHz (Quad-Core)
Processor Socket
LGA1356 Socket
Processor Main Features
Intel Extended Memory 64 Technology, Intel Smart Cache
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
4 GB (installed) / 192 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SAS (SATA 6Gb/s / SAS) - PCIe 3.0 x8 (ServeRAID M1115)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
OS Provided
No operating system
Software Included
IBM ServerGuide, IBM Systems Director, IBM Systems Director Active Energy Manager
23.5 cm x 67.8 cm x 43.8 cm
22 kg
Manufacturer Selling Program
IBM Express
Limited warranty - 3 years - on-site - response time: next business day
Server
Product Form Factor
Tower
Built-in Devices
Led panel
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Front Accessible Bays Qty
2
Hot-Swap Bays Qty
8
Region: EMEA
Processor / Chipset
CPU
Intel Xeon E5-2407
Clock Speed
2.2 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1356 Socket
Chipset Type
Intel C600
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
4 GB / 192 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1066 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
12 (Total) / 11 (empty)
Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, slots 7 - 12 are available in two-processor configuration only
Configuration Features
1 x 4 GB
RAM Supported
192 GB registered , 48 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x SAS - plug-in card - PCIe 3.0 x8
Controller Interface Type
SATA 6Gb/s / SAS
Storage Controller Name
ServeRAID M1115
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I350-CM2
Remote Management Controller
Integrated Management Module II (IMM2)
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 8 (total) / 8 (free) x hot-swap 2.5"
Slots
2 (total) / 1 (free) x CPU , 12 (total) / 11 (free) x DIMM 240-pin , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode)
6 x USB 2.0 (2 front, 4 rear) , 1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x management
Administrator password, power-on password, cover key lock, predictive failure analysis (PFA), automatic server restart (ASR)
TUV GS, NOM, CCC, IEC 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1
IBM Express
Power supply - hot-plug
Installed Qty
1
Max Supported Qty
2
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Provided
No operating system
Software
23.5 cm
67.8 cm
43.8 cm
22 kg
5 °C
8 - 85% (non-condensing)
918T C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
918T C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
