IBM 600GB 15K 3.5-inch HDD
Quicklinx: B9VGWS00 Mfr#: 49Y1870
This IBM System Storage 600GB 15Krpm 6Gb SAS 3.5 inch HDD FRU 49Y1870 requires an available disk drive bay in an IBM DS3512 or EXP3512 expansion unit. IBM best practices for this 49Y1870 Hard Disk Drive require a minimum Model Type 1746 firmware revision of 07.70.16.01 and a minimum EXP3500 ESM firmware revision of 3.16. Contact our Technical Support team if you need assistance in ordering or integrating this HDD into your existing IBM System Storage environment.
IBM - hard drive - 600 GB - SAS
Hard drive - hot-swap
600 GB
3.5"
SAS
Data Transfer Rate
300 MBps
Spindle Speed
15000 rpm
600 GB
3.5"
SAS
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
15000 rpm
Expansion & Connectivity
1 x SAS
Compatible Bay
3.5"
