HyperX SoloCast USB Microphone
Quicklinx: HTRGWS00 Mfr#: 4P5P8AA
Type: Mic
£64.12 ex VAT
£76.94 inc VAT
For video editors, streamers, and gamers looking for a USB microphone with great sound quality, the HyperX SoloCast is a must have. Get 24-bit, 96kHz recordings with the SoloCast's high bit depth and sampling rate. It's Plug N Play with a USB-C connection, making it simple to use, with some of our fan-favorite conveniences like the tap-to-mute sensor and LED mute indicator. The versatile microphone has a flexible, adjustable stand and is also compatible with most boom arms, so it can either sit on your desk or work mounted. Certified by TeamSpeak and Discord and compatible with OBS, XSplit, Streamlabs OBS and a number of other programs, it's an extremely streamer-friendly microphone.
  • Plug N Play audio recording
    Get quality audio recordings with this easy-to-use USB condenser microphone. The cardioid polar pattern prioritizes sound sources directly in front of the microphone.
  • Tap-to-Mute sensor with LED status indicator
    Simply tap the top of the mic to mute, and the signature LED indicator lets you immediately see whether or not you're broadcasting.
  • Flexible, adjustable stand
    The easy-to-position stand swivels to support a variety of setups. You can even fit it under a monitor if your setup is tight on space.
  • Boom arm and mic stand threading
    Versatile microphone fits 3/8-inch and 5/8-inch threaded setups, making it compatible with most mic stands or boom arms.
  • Multi-device and program compatibility
    Get great sound whether you're connecting to a PC, PS5, PS4, or Mac. SoloCast is certified by Discord and TeamSpeak, and works on major streaming platforms like Streamlabs OBS, OBS Studio, and XSplit.
HyperX SoloCast - microphone
Microphone - USB
Recommended Use
Game console, computer
Microphone
Tabletop
Microphone Technology
Electret condenser
Microphone Operation Mode
Cardioid
HP 250 G9; Laptop 15, 15s, 17; Pavilion Laptop 15; Workstation Z2 G9
Microphone - USB
Dimensions & Weight Details
Microphone stand: 125 g ¦ Microphone with stand: 386 g ¦ Microphone: 261 g
429.9 g
Recommended Use
Microphone
Recommended Placing
Tabletop
Electret condenser
Cardioid
Wired
Sensitivity
-6 dBV/Pascal
Frequency Response
20 - 20000 Hz
Mute function
Audio Input Details
Cardioid - 20 - 20000 Hz
Connector Type
USB
Microphone stand
Cable Details
USB-C to USB-A cable - 2 m
HP 250 G9 Notebook ¦ HP Laptop 15-dw1026nq, 15-dw1094nf, 15-dw3003nq, 15-dw3677nz, 15s-eq1007nm, 15s-eq1008nb, 15s-eq1008no, 15s-eq1085nl, 15s-eq1164nf, 15s-eq1355ng, 15s-eq1530au, 15s-eq1544au, 15s-eq1900nc, 15s-eq2005nw, 15s-eq2019nu, 15s-eq2021au, 15s-eq2032nl, 15s-eq2039nl, 15s-eq2040nl, 15s-eq2045nf, 15s-eq2050nl, 15s-eq2055nu, 15s-eq2059nl, 15s-eq2059ns, 15s-eq2060nl, 15s-eq2061nl, 15s-eq2067nf, 15s-eq2077ns, 15s-eq2088ns, 15s-eq2091ns, 15s-eq2433ng, 15s-eq2458ng, 15s-eq3456ng, 15s-eq3634nz, 15s-fq0084nf, 15s-fq1135ns, 15s-fq2060nl, 15s-fq2060ns, 15s-fq2068ns, 15s-fq2080nl, 15s-fq2081nl, 15s-fq2094nl, 15s-fq2153ng, 15s-fq2153ns, 15s-fq2226nd, 15s-fq2412nd, 15s-fq2596TU, 15s-fq2600tu, 15s-fq3002ny, 15s-fq3005no, 15s-fq3025nf, 15s-fq3412ng, 15s-fq4011tu, 15s-fq4021ns, 15s-fq4023nl, 15s-fq4023ns, 15s-fq4044ns, 15s-fq4045ns, 15s-fq4454ng, 15s-fq4455ng, 15s-fq5304nz, 15s-fq5504nz, 15s-fq5704nz, 17-cn0026nq, 17-cn0040na, 17-cn0334ng, 17-cn0336nf, 17-cn0355ng, 17-cn0413ng, 17-cn0429ng, 17-cn0435nf, 17-cn0448nf, 17-cn0453ng, 17-cn0490nf, 17-cn0515nf, 17-cn0524na, 17-cn0526nf, 17-cn0527nf, 17-cn0780ng, 17-cn0833nd, 17-cn1270nd, 17-cp0002ns, 17-cp0003nl, 17-cp0009na, 17-cp0153ng, 17-cp0255ng, 17-cp0256ng, 17-cp0272ng, 17-cp0293nf, 17-cp0295nf, 17-cp0297nf, 17-cp0437ng, 17-cp0456ng, 17-cp0636ng, 17-cp0658ng, 17-cp0778ng, 17-cp1424nz ¦ HP Pavilion Laptop 15-eg0044nl, 15-eg0050nl, 15-eg0051nl, 15-eg0121nf, 15-eg0122nf, 15-eg0123nf, 15-eg0127od, 15-eg0174ng, 15-eg1003nl, 15-eg1004nl, 15-eg1004ns, 15-eg1007nq, 15-eg1018nu, 15-eg1020nl, 15-eg1027nu, 15-eg1028nu, 15-eg1035nb, 15-eg1035nu, 15-eg1445nd, 15-eg2504nz, 15-eg2530nz, 15-eg2704nz, 15-eg2750nz, 15-eh0523na, 15-eh0900nd, 15-eh1003nq, 15-eh1004nu, 15-eh1005nk, 15-eh1014nl, 15-eh1024nb, 15-eh1031nq, 15-eh1033nb, 15-eh1042nf, 15-eh1042nq, 15-eh1043nf, 15-eh1060au, 15-eh1321nd, 15-eh1360nd, 15-eh1362nd, 15-eh1435nd, 15-eh1436nd, 15-eh2900ng ¦ HP Workstation Z2 G9
Type: Mic
Brand: HyperX
